For the labarotary analysisi, what are the differences between Perchloric Acid And Sulphuric Acid? If i use perchloric acid instead of sulphuric acid, what will be the result?
Difference Between Perchloric Acid And Sulphuric Acid In Lab Analysis
Posted 15 December 2015 - 03:30 PM
Posted 15 December 2015 - 03:46 PM
As the first responder, I guess I get to give the most obvious difference: perchloric acid is a monoprotic acid where sulphuric acid is a diprotic acid. So, if the acidic character is a quantitative part of the analysis, you may need to account for this difference.
It also seems that perchlorate salts are generally soluble in water. Some sulphate salts are minimially soluble, and sulphuric acid may be preferred reagent because the salt will precipitate out. If precipitation of a sulphate salt is a part of your analysis, the use of perchloric acid probably defeats this purpose.
Your question is very generic, and I'm not sure how many generic answers there are.
Posted 15 December 2015 - 11:58 PM
Sulfuric acid is a dissolving acid. Reacts with oxides of metals giving soluble sulfates (except a few such as Barium sufate, Lead sulfate). Whereas perchloric acid is a strong oxidizing agent. It oxidizes organic matter also apart from some inorganic compounds. By strength it is weaker than sulfuric acid. Perchloric acid is a monovalent acid and sulfuric acid is a divalent acid. Please refer to any book on Inorganic Analysis for more.or Wikipedia.
Sulfuric Acid PlantStarted by Guest_Kartik54_* , 16 Mar 2024 |
Linear Alkyl Benzene Sulfonic Acid Production (Labsa) SimulationStarted by Guest_Emranm02_* , 03 Mar 2024 |
Sulfuric Acid Production / Partial Pressure Of H2So4Started by Guest_Jon K_* , 22 Sep 2023 |
Diluting Of Sulphuric Acid In Water Treatment Plant IndustriesStarted by Guest_YUMI_* , 15 Jan 2023 |
Ecolab Alkaline & Acid Cip Chemical PricesStarted by Guest_George Lee_* , 14 Jul 2023 |
