Question - Why we design fire water system at 9kg/cm2g. Residual pressure at 5.6kg/cm2g and Pressure at remotest distance should be 7.0 kg/cm2g?
Posted 19 December 2015 - 03:53 AM
Posted 19 December 2015 - 04:52 AM
You should check your local regulation and contact your fire brigade for more info .
You need to supply sufficient water at the right pressure to operate the equipment ( guns, sprinklers, etc at any points of your plant .
In my place the pressure in the main is about 12barg
If you are working in a plant , you should consult the insurance company in charge of your facility .
Hope this helps.
Edited by breizh, 19 December 2015 - 05:10 AM.
Posted 19 December 2015 - 05:38 AM
Dear Gourav,
It all depends on the local fire fighting regulation.I have seen this all conditions are different in different country and every different project.
I have seen the pressure from 12 to 7 Kg/cm2g.
Manoj
Waste WaterStarted by Guest_refluxraider_* , 14 Apr 2024 |
Water Seal DrumStarted by Guest_Ali4269278331_* , 05 Apr 2024 |
Handling The Limited Capacity Of Flare SystemStarted by Guest__1angelia23_* , 05 Apr 2024 |
Closed Drain SystemStarted by Guest_Falah_* , 26 Mar 2024 |
Rapid Depressurization Of WaterStarted by Guest_golegolegole_* , 31 Mar 2024 |
