I dont have chemical background but i want to find some subtances with specific properties for a project, is there any software or document to find subtances (mostly solvents)?
Maybe you may help me what kind of subtances do i need,
we have 3 subs let's assume them x,y,z
x and y missicble, y and z missicble, x and z immisicble.
when y-z solution mix with x, i want to get x-y solution and z (mostly released from solution)
also mass of X < Y (it will be better when rate of y/x is highest possible) and mass of Y < Z (also it will be better when rate of z/y is highest possible)
on the other hand, boiling point of the Z < X (high x/z rate is better) and the boiling point of Y > X ( high y/x rate is better)
Thank you in advance.
