Lean TEG iron content measured and found that 220 ppm and pH dropped to 3.5, colour was dark brown.
Added MEA into the system and brought down iron content to 120 ppm and pH increased into 7.0.
It took one week to get back to this condition. Post adding MEA into the system observed Surge drum temperature rise and iron content came down by filtration. I suppose addition of MEA precipitated out iron from the glycol stream and got filtered in filters.
Now pH got stabilized but iron content again increased back to 400 ppm and colour turned into black. Rich and lean glycol sample looks same black coloured. But concentration is maintaining around 99 % above. I guess if glycol got degraded it won't be regenerating.
Further adding of MEA is not helping iron to get out of the solution. Filter differential pressure is maintaining constant. No rise is observed.
If Lean glycol is diluted with equal amount of water after some time black particles settling up leaving glycol n water down whereas its opposite to rich stream. When diluted with water, black particles settling down.
Questions:
Will adding of MEA increase the system temp always ?..
With the above explained condition how to get the glycol back into its normal condition. I guess it's not degraded as its regenerating.
Iron Content Trouble Shooting In Teg Dehydration System
Started by Papps, Jan 17 2016 08:50 AM
No replies to this topic
Posted 17 January 2016 - 08:50 AM
Handling The Limited Capacity Of Flare SystemStarted by Guest__1angelia23_* , 05 Apr 2024 |
Closed Drain SystemStarted by Guest_Falah_* , 26 Mar 2024 |
Lube Oil System For TurbomachineryStarted by Guest_bckesim_* , 03 Mar 2024 |
Design Criteria For Sizing Sump Drum Of Close Drain System In Tank FarStarted by Guest_AnbIran_* , 28 Feb 2024 |
Water Injection SystemStarted by Guest_Frederick34_* , 08 Jan 2024 |
