Relieve Device Discharge Line Size
psv discharge relieve tail
11 replies to this topic
#1 farhan ahmed
farhan ahmed
  • 7 posts
Posted 20 January 2016 - 01:23 AM
I have come across a problem regarding the discharge line size of psv.
PSV tail pipe is sized based on the Rated flow of PSV . Due to this Discharge line dia become higher than the main header.
Can we go for the larger  tail pipe size than the main header . Please give suggestion and codes and industry practices recommendations.
#2 fallah
  • 4,951 posts
Posted 20 January 2016 - 02:00 AM
This can be happened if 1) there would be high difference between required and rated flow of PSV and 2) there is just one PSV at any time from which the relevant relief will be handled by flare main header and the relief from a PSV with highest required relief area has been considered as governing case.
In such rare case you can take the same size of PSV tail pipe for the main header...
#3 farhan ahmed
farhan ahmed
  • 7 posts
Posted 20 January 2016 - 04:28 AM
Thanks Fallah
Actually I am working on the existing flarenetwork and PSV to be added in the existing system. Here I want to avoid the changes in existing flare header. For this case , can I use the higher tail pipe size than the existing header size as I am considering rated flow in tail pipe.
#4 fallah
  • 4,951 posts
Posted 20 January 2016 - 04:33 AM
Thanks Fallah
You can, but the relieving bottleneck will be shifted from tail pipe to main header...!
#5 Sardar Shahnawaz
Sardar Shahnawaz
Posted 20 January 2016 - 04:45 AM
Hi Farhan,
Please note that if you are having problem related to the back pressure and it resolves by increasing tail pipe size then it is OK, but you must also check velocity criteria for both header and tail pipe.
#6 flarenuf
flarenuf
  • 104 posts
Posted 20 January 2016 - 06:02 AM
hi farhan
what is your calculated size for the tailpipe and what is your size for the header?
normally the tailpipe is sized for rated flow but once it reaches the main header you should be using design flow.
what are you sizing the TP on , backpressure or velocity ?
the built up back pressure from the tie in to header back to the PSV outlet flange shouldn't be that large surely ?
is this PSV flowing individually or part of a scenario ?
are you saying you have to have a large diameter TP in order to meet BP limits on valve ?
conventional PSV ?
please give more info
brian
#7 Bobby Strain
Posted 20 January 2016 - 11:08 AM
Seems that maybe you are not properly analyzing the system. If you provide details, we can all stop guessing.
#8 S.AHMAD
S.AHMAD
  • 786 posts
Posted 27 January 2016 - 03:37 PM
Agree with Bobby. Proper sizing and piping for psv  is critical in process units for safety reasons.
s.ahmad
Edited by S.AHMAD, 27 January 2016 - 03:38 PM.
#9 farhan ahmed
farhan ahmed
  • 7 posts
Posted 31 January 2016 - 11:17 PM
Dear Flarenuf
Calculated tail pipe size is 14'' and header size is 10''
what are you sizing the TP on , backpressure or velocity ? I am considering Backpressure.
the built up back pressure from the tie in to header back to the PSV outlet flange shouldn't be that large surely ? Back pressure is increasing largely.
is this PSV flowing individually or part of a scenario ? PSV  is flowing in blocked oulet case.individually and collectively in fire scenario.
are you saying you have to have a large diameter TP in order to meet BP limits on valve ? YES
conventional PSV ?YES
#10 Bobby Strain
Posted 01 February 2016 - 04:43 PM
If you show us your calculation results, along with flow and properties, and a sketch with dimensions, maybe we can help. Something about your analysis seems wrong. But you fail to supply sufficient information.
#11 flarenuf
flarenuf
  • 104 posts
Posted 15 February 2016 - 07:41 AM
judging by the lack of response in over 2 weeks to bobbys comment on this topic Farnhan i guess you have found out where you have gone wrong in your calcs
thanks for the update
#12 christopherchoa
christopherchoa
  • 63 posts
Posted 24 February 2016 - 08:03 PM
Any updates Farnhan?
