Dear Gentlemen,
In my plant we have HP (106 kg/cm2) steam system. I want to calculate steam losses from vent valve. I don't have characteristic curve of the valve. Kindly help me to calculate vent steam flow by valve opening.
Thanks & Regards,
Posted 05 February 2016 - 01:46 AM
Dear Gentlemen,
Thanks & Regards,
Posted 05 February 2016 - 01:56 AM
The size and type of the valve....?
Posted 05 February 2016 - 02:07 AM
check valve details in attachment.
Posted 06 February 2016 - 02:49 AM
Is it a check valve or vent valve?
Posted 07 February 2016 - 12:59 AM
It's vent valve.
Posted 07 February 2016 - 01:27 AM
It's vent valve.
But, you did submit the detail of check valve...
Posted 07 February 2016 - 03:54 AM
Talk to the vendor , the only one to answer about the valve ( Cv vs Opening & DP) . To me you may have to install a flow meter like annubar or similar device to measure the flowrate (based on similar application)
Hope this helps
Posted 12 February 2016 - 09:01 PM
Iso 28300 Venting CalculationsStarted by Guest_Mikemak_* , 22 Feb 2024 |
Steam Trap & Condensate RecoveryStarted by Guest_salihbaykal_* , 10 Jan 2024 |
Drain Line Sizing To Steam TrapStarted by Guest_RaifOzturk_* , 05 Jan 2024 |
Psv Relief Scenario (Steam)Started by Guest_panagiotis_* , 01 Jul 2023 |
Reducing Steam Consumption In Vacuum Packed DistillationStarted by Guest_dpunnn_* , 30 Nov 2023 |
