A re-circulation line from brackish water pump discharge header back to storage tank is to be provided. What should be the height of re-circulation nozzle in the brackish water storage tank? Should it be below 'LL' of the tank or between 'NLL' normal Liquid Level and HH? Kindly advice guidelines on the nozzle heights in storage tanks please
Re-Circulation Nozzle Height In Water Storage Tanks
Started by RUBABU, Feb 06 2016 12:07 AM
storage tanks recirculation nozzle height
Posted 06 February 2016 - 12:07 AM
Posted 06 February 2016 - 01:50 AM Best Answer
RUBABU,
Recirculation nozzle height could be at the top of the tank and can be extended to any level via an internal dip pipe...in general if LL level is sufficiently above the bottom it's better the outlet to be below LL otherwise the proper height might be between LL and NLL...
Waste WaterStarted by Guest_refluxraider_* , 14 Apr 2024 |
Sulphuric Acid H2So4 Storage TankStarted by Guest_TeeEng_* , 08 Apr 2024 |
Water Seal DrumStarted by Guest_Ali4269278331_* , 05 Apr 2024 |
Rapid Depressurization Of WaterStarted by Guest_golegolegole_* , 31 Mar 2024 |
Butadiene StorageStarted by Guest_Mirzazada_* , 27 Mar 2021 |
