Hydrocarbons with carbon dioxide are coming out of my reactor. At the stream pressure, using the antoine equation i've found that carbon dioxide is above its boiling point whereas the hydrocarbons are not. I am making the assumption that some of the carbon dioxide will be dissolved in the liquid stream , in which case I have to remove it.
I know how to perform standard gas liquid separation , (flash, distilation , etc) but I don't think it should undergo phase equilibrium separation, since carbon dioxide is already gas.
I think I have to use a knock-out drum, but the equations i've found only correlate the maximum vapour velocity to the separator empirical constant (Kv) and the densities of the liquid and gas phases. How does this take into consideration the dissolved vapour? I am supposed to assume that the liquid density includes the dissolved component?
Vv=Kv ((ρL-ρV)/ρV)1/2
Also how does this take into account the residence time in the separator, the degree of separation achieved and the actual size of the separator? Is there something I am missing?Should I be performing a flash calculation instead?
*Edit: Out of the hydrocarbon product mixture , another product is gaseous, which further complicates things.
Edited by ChemEng16, 12 March 2016 - 12:01 PM.
