Hi all,
A gas with attached composition (MW: 24.12) needs to be compressed. Conditions are as follows:
Suction pressure: 4.6 kg/cm2g, Discharge pressure: 37 kg/cm2g, Suction Temperature: 56 DegC
We are planning to use a multistage centrifugal compressor for this purpose.
As you can see, there is a high percentage of olefins in the gas.
Is there any special consideration/ safeguard that needs to be taken for compressing this gas, say w.r.t. maximum allowable outlet temperature, risk of polymerization etc.?
Awaiting your response and thank you for your time.
Rajarshi
