@ Mahdi,
1. I would like to suggest a correction in your answer. The work done is defined as always PdV, it can never be VdP.
So you cannot consider the work done to be VdP.
2. Also, in this case, the work done will be =0, since there is no volume change in incompressible liquids.
@ Julien,
1. The process described here would be adiabatic, since no heat is added to or removed from the system externally.
Also, the work done by the fluid would ideally be =0, since liquids can be considered to be incompressible.
2. If you were to consider it in simple terms,
dQ = dU + d(PV)
dQ (Heat change) = dU (internal energy change) + PdV (work done by system) + VdP
3. Now in your case, since it is an adiabatic process (dQ=0) and a liquid, assume certain incompressibility (dV=0).
So we get PdV = 0
Thus, from, dQ = dU + PdV + VdP, we get,
and dU = -VdP
4. But, we know that the dP<0 since your pressure at the outlet is lesser.
So, we thus get
dU > 0
5. Internal energy is nothing but a measure of the inherent energy your fluid possesses by virtue of its temperature, and thus it is only dependent on the temperature of the fluid.
Since your internal energy is increasing here (as seen from dU>0 ), your temperature thus has to proportionally increase.
That is why your outlet temperature is higher.
6. In the Joule Thomson effect, the fluid in consideration expands too, so there is also an additional work term involved (PdV). This is why the internal energy change there has also got a possibility of becoming negative, which is why we see lower outlet temperatures too in JT effect.
But in this case, there is no work done due to incompressibility of fluid, so your temperature of the fluid can only increase when outlet pressure is lesser, as per the equation.
7. Also, if I were to put it in simple terms, in the JT effect, the heat contained in a fluid is utilized in doing work on that fluid, thus lowering overall heat content of the fluid itself and thus reducing the temperature.
But in this case, there is no work done. So whatever reduction in pressure is observed has to be compensated only by increasing the temperature of the fluid since work cannot be done.
Shantanu
Edited by shantanuk100, 15 April 2016 - 01:54 AM.
