Centrifugal Air Compressor Malfunction
8 replies to this topic
#1 trungphu
trungphu
  • 106 posts
Posted 14 April 2016 - 10:26 PM
Hello everyone,
I would like to share a malfunction in our air centrifugal compressor. The compressor driven by a steam turbine has five stages. Recently we found that pressure at outlet of third stage has increased 1.6 bar, from 8.2 to 9.8 barg, and the opening of IGV at inlet of first stage has increased from 55% to 90%. The other operating parameter of the compressor is normal.
Well, I wonder if someone can answer my queries regarding the above malfunction: Have you ever encountered that problem? What might be the reason for it?
Thanks and best regards,
Trung Phu
Edited by trungphu, 18 April 2016 - 08:47 AM.
#2 cea
cea
  • 108 posts
Posted 14 April 2016 - 10:50 PM
Can you furnish some more data, such as
1) Any change in steam consumption in steam turbine
2) Temperature & Pressure at each stage outlet (New as well as old)
3) Change in any utility condition / flow (such as cooling water)
4) Conditions at surface condenser
I think, forum can help you if you provide all such data.
#3 Mahdi1980
Mahdi1980
  • 182 posts
Posted 16 April 2016 - 03:54 AM
What do you mean by "Opening of IGV at inlet of the first stage of compressor"?
In addition to the information that Cea requested, please let us have the P&ID of the compressor package
and the performance curve of the compressor if available.
Mahdi
#4 breizh
  • 6,346 posts
Posted 16 April 2016 - 04:29 AM
Hi Trung Phu ,
Did you contact the vendor ? Certainly not the 1rst time they encounter such issue .
May be time for inspection and overhaul ?
Edited by breizh, 18 April 2016 - 05:19 PM.
#5 trungphu
trungphu
  • 106 posts
Posted 18 April 2016 - 08:55 AM
The attached is a drawing of air compressor with its parameter. This is for your reference. Pressure at outlet of third stage has increased 1.6 bar, from 8.2 to 9.8 barg.
#6 ankur2061
ankur2061
  • Forum Moderator
  • 2,484 posts
Posted 18 April 2016 - 01:49 PM
trungphu,
Contacting the compressor manufacturer would be the best option for troubleshooting. Meanwhile, your maintenance team can attempt  some troubleshooting based on some generic troubleshooting guidelines as given in:
http://www.cheresour...ting-checklist/
#7 Bobby Strain
Posted 18 April 2016 - 06:50 PM
Trung,
      You need to compare the operating data with the design data, in a tabular form. The DCS screen shot doesn't lend itself to good analysis without a lot of work. You should do that work, not us.
#8 Mahdi1980
Mahdi1980
  • 182 posts
Posted 19 April 2016 - 09:08 AM
Trungphu
As my friends told you, please check all process data and trends first . You should check the pressure trends and find when this pressure increase at the 3rd stage has happened and then check other operating conditions and process data such as discharge valves opening, intercoolers, etc.
If there is no sensible change through them, it may be a mechanical trouble within the 3rd stage and need to contact vendor..
Mahdi
#9 trungphu
trungphu
  • 106 posts
Posted 20 April 2016 - 03:21 AM
Thank you all so much for your advices. I really appreciate it.
Edited by trungphu, 20 April 2016 - 03:21 AM.
