Desalter Wash Water Heat Excahnger Fouling
Posted 19 April 2016 - 04:26 AM
Posted 04 May 2016 - 01:46 PM
Dear Sir
The combination of 02 different water leads to scale formation.In your case try to use only 01 kind and do not mix them.
Posted 04 May 2016 - 10:17 PM
Check your service water quality. If it contains large quantity of temporary hardness, it forms scales.
Posted 05 May 2016 - 02:29 AM
Sometimes, the water source is very important. Combining two different sources (different TSS, salts contents, etc.), you could obtain a certain incompatibility between the two water streams. I suggest to consider first Laboratory analysis in order to see the water mixture behavior.
Waste WaterStarted by Guest_refluxraider_* , 14 Apr 2024 |
Water Seal DrumStarted by Guest_Ali4269278331_* , 05 Apr 2024 |
Rapid Depressurization Of WaterStarted by Guest_golegolegole_* , 31 Mar 2024 |
