how can i size a three phase separator in aspen-hysys?
Three Phase Separator Sizing
Posted 19 April 2016 - 08:03 PM
Posted 19 April 2016 - 11:34 PM
Hamzzuss
First of all you should know the principles of selection and sizing of a 3-phase separator.
For instance, when it should be vertical and when to be horizontal.
Then in Hysys, after adding materials and equation state you will enter the simulation environment.
Then you add an material stream and define the parameters and compositions.
In the next stage , you should choose the separator from the Pallet.
After defining the inlet and outlet streams and probable pressure drop, run the simulation.
Then go to rating tab and select quick size to obtain the diameter and height of cylinder or sphere.
Here to have a good design, you should know realize the principles of sizing and selection.
Mahdi
Posted 20 April 2016 - 05:04 AM
Hi hamzzuss
I think you can obtain the physical properties from Aspen HYSYS ( density, viscosity, flow...) and use them in the SPREADSHEET where you put the equation and some of constant like K and L/D ratio to achieve your design,
Also there is an option (vessel Design) in Apen HYSYS that you can use it, (I used one time and I found weird results) so you can use both of methods and let us know what you got.
Walid,
Posted 20 April 2016 - 12:58 PM
Flash Steam Vessel SizingStarted by Guest_JohnFields343_* , Yesterday, 12:03 PM |
Pump Sizing ConsiderationsStarted by Guest_panagiotis_* , 07 Apr 2024 |
Barometric Legs Line SizingStarted by Guest_panagiotis_* , 17 Mar 2023 |
Sizing Of Vertical/horizontal Flash DrumStarted by Guest_Mohammad3799_* , 10 Mar 2024 |
Design Criteria For Sizing Sump Drum Of Close Drain System In Tank FarStarted by Guest_AnbIran_* , 28 Feb 2024 |
