Hi all,
I have query related to TEG system.
Is there any formula or chart that relate TEG Unit Circulation Rate (UCR) with TEG purity?
Your help is highly approciated.
Sulaiman
Posted 21 April 2016 - 12:23 AM
Hi all,
Sulaiman
Posted 21 April 2016 - 08:14 AM
Sulaiman:
Are you at least familiar with the TEG process for natural gas dehydration?
The amount of TEG circulated in unit time (flow rate) is not related to the "purity" of the TEG.- or the amount of water that it absorbs in the TEG absorber. The TEG regeneration system (the stripper-reboiler) is designed to regenerate a certain amount of maximum TEG flow rate and you don't surpass that flow rate. What is the nature of your question? Why do you ask it?
Handling The Limited Capacity Of Flare SystemStarted by Guest__1angelia23_* , 05 Apr 2024 |
Closed Drain SystemStarted by Guest_Falah_* , 26 Mar 2024 |
Lube Oil System For TurbomachineryStarted by Guest_bckesim_* , 03 Mar 2024 |
Design Criteria For Sizing Sump Drum Of Close Drain System In Tank FarStarted by Guest_AnbIran_* , 28 Feb 2024 |
Water Injection SystemStarted by Guest_Frederick34_* , 08 Jan 2024 |
