One of our field operator recently performed a pressure test to determine if there is a leak in one of our heat exchangers. He closed both sides of the tubes and pressured it to 400 psig. He says that the pressure held for over an hour and therefore he does not believe there is any leak. However, I have recently gotten the sample for the inlet and outlet of the heat exchanger and they are very different (which tells me that there may be a leak).
My question is: is it possible that he has done the test incorrectly and thus failed to detect the leak?
Any advice would be much appreciated.
Thank you,
