Liquid Phase Residence Time In Kettle Exchanger
Started by Vegeta, May 27 2016 03:13 PM
Posted 27 May 2016 - 03:13 PM
Dears,
How to calculate the residence time of the liquid in a kettle vaporizer?
I am using HTRI to model my exchanger and I don't know if such information is available and calculated by the software.
Posted 27 May 2016 - 04:20 PM
Why do you need such a value?
Posted 27 May 2016 - 11:47 PM
Bobby,
I need it because I am evaluating a chemical reaction that takes place in the kettle.
Posted 28 May 2016 - 05:55 PM
You might try Google. Meanwhile, I would use 50% of the volume in the shell (minus tube volume) below the liquid level. And treat it as a stirred tank reactor, not plug flow. Most important for you is to develop your kinetic model first. Bother with the details last. After all, this is only an academic exercise.
Posted 31 May 2016 - 10:52 AM
Thanks Bobby,
As far as I know the residence time = the Volume / the volumetric flow rate. The volume can be calculated from the data of HTRI but what about the volumetric flow rate? Do we consider the liquid rate or the average of the liquid & leaving vapor volumetric flow rate ?
Does the tube length in HTRI include the U bend?
Sorry for my many questions
Kettle Reboiler Flow FractionsStarted by Guest_Lyne_* , 31 Mar 2024 |
Time Required To Heat Up A Fluid In A VesselStarted by Guest_panagiotis_* , 24 Jan 2023 |
Plate Fin Heat ExchangerStarted by Guest_shazzad1613_* , 23 Mar 2024 |
Duplication Of Psv And Flow Rate For Exchanger Tube Rupture ScenarioStarted by Guest_Platonicus_* , 11 Mar 2024 |
Kettle Reboiler LengthStarted by Guest_Lyne_* , 26 Feb 2024 |
