Dear Members
We are facing currently problem with water slug in our Oil and gas processing plant.
Let me start with the beginning.
Our onshore terminal receives oil+water emulsion from the offshore via a 35 Km long sub-sea pipeline.It gets collected into a slugcatcher(operating at 7 barg and 30 Deg C).Afterwards oil+water emulsion is heated in a heater upto 80 Deg C and fed to the horizontal separators for separating oil and water. We used to dose demulsifier in the heater inlet and were getting fine result with the required water and oil separation.
After increased water cut from the offshore wells,demulsifier dosing seemed ineffective in terms of seperation,so after much brain storming ,demulsifier dosing was started from offshore also in the subsea pipeline.
Now we are facing problem with water slug in the slugcatcher.It seems that because of longer subsea pipeline length,high residence time is creating water separation and resulting in water slug. Demulsifier dosing is already reduced to minimum possible from offshore.
Can we dilute demulsifier with diesel and then dose into subsea pipeline?Will reducing demulsifier concentration be effective same as in terms of reducing residence time?
Aditya
