During Blowdown and flare System Review we performed FlareNet simulation we've detected high back pressure and vivration on some lines. We've increased the in order to resolve these issue.
The Problem is the following:
- Flarenet results are static back pressure and total back pressure ( Static + dynamic) . Which one should we use to select the back pressure Knowing the fact that for 2 " pipe the static back presure is 30 bar the tatal BP has a very similar value however when increasing the piping diameter to 6" the static back pressure is 2 bar and the total BP is 25 bar.
- Furthermore the Back pressure has a big impact on the discharge temperature (RO outlet) should I use the static or the total PB to estimate it
Blowdown And Flare System Piping Class Selection
Started by kc2010, Jun 22 2016 04:24 AM
back pressure flare blowdown minimum temperature
Posted 22 June 2016 - 04:24 AM
Posted 28 June 2016 - 08:39 PM
kc2010
The pressure we consider in process system is static pressure. you can see in API 520 that all pressure mentioned in the code is highlighted as "static". Total pressure is the combination between static and dynamic which includes the velocity head.
Handling The Limited Capacity Of Flare SystemStarted by Guest__1angelia23_* , 05 Apr 2024 |
Closed Drain SystemStarted by Guest_Falah_* , 26 Mar 2024 |
Lube Oil System For TurbomachineryStarted by Guest_bckesim_* , 03 Mar 2024 |
Piping Design_ Pump PipelineStarted by Guest_anh.phungthai@boydensvn_* , 29 Feb 2024 |
Design Criteria For Sizing Sump Drum Of Close Drain System In Tank FarStarted by Guest_AnbIran_* , 28 Feb 2024 |
