Water Chemistry
10 replies to this topic
#1 Baqa Baloch
Baqa Baloch
  • 5 posts
Posted 27 June 2016 - 01:41 AM
We have Niagara Bowler Wet Surface Air Cooler installed on our compressor gas outlet. Someone help me for the quality of water to be used in these coolers.
Service: Sales Gas Cooler
Mass Flow Rate (lb/hr): 20,540 lb/hr
Temperature In / Out: 160 / 115 oF
Design Heat Load: 590,100 Btu/hr
Cooling Tube Material: SA-249-316/316L SS
Header Material: SA-240-316 SS
Basin / Plenum Material: Carbon Steel, H.D.G.A.F (HOT DIPPED GALVANIZED AFTER FABRICATION)
Edited by Baqa Baloch, 27 June 2016 - 01:52 AM.
  • 6,328 posts
Posted 27 June 2016 - 03:00 AM
You should ask the person /company in charge of the treatment of the cooling water in your facility , he knows the quality of your make up water .
Hope this helps a bit.
#3 Baqa Baloch
Baqa Baloch
  • 5 posts
Posted 27 June 2016 - 11:51 PM
Thanks,
We have below mentioned water available at our site.
Demin Water: pH (6.98), TDS (0.5 mg/L) & Conductivity (1.02 µS/cm)
Portable Water: pH (6.91), TDS (11.2 mg/L) & Conductivity (24.0 µS/cm)
Utility Water: pH (6.91), TDS (1433 mg/L) & Conductivity (2810 µS/cm)
Edited by Baqa Baloch, 27 June 2016 - 11:55 PM.
#4 breizh
  • 6,328 posts
Posted 28 June 2016 - 12:12 AM
To me your water (all) is good quality water !  Utility water should be used .
Hope this helps
#5 P.K.Rao
P.K.Rao
  • 265 posts
Posted 28 June 2016 - 01:22 AM
Looks like chlorides are high in your utility  water. What is the chloride and bicarbonte of utility water? Chlorides are detrimental to SS and bicarbonates will form scalle. Calculate Langlier Index and Stability Index (LI) and (SI). Both  will tell about the nature of water (scale forming or corrosive).  You have to action accordingly..
#6 breizh
  • 6,328 posts
Posted 28 June 2016 - 01:39 AM
hi ,
I agree with P.K Rao in general , still needto  investigate with the company in charge of the treatment .
My thoughts
#7 Baqa Baloch
Baqa Baloch
  • 5 posts
Posted 28 June 2016 - 01:40 AM
Yes, we used utility water but cooler water spray nozzles frequently chocking due to deposition of salt particles causes tripping of compressor at after cooler high temperature.
Edited by Baqa Baloch, 28 June 2016 - 01:44 AM.
#8 Baqa Baloch
Baqa Baloch
  • 5 posts
Posted 28 June 2016 - 01:46 AM
Yes Chlorides are 584 mg/L and Sulfates are 380 mg/L in Utility water.
I want to share some pics of salt deposited in water spray nozzles but I don't know how to paste pics here.
Edited by Baqa Baloch, 28 June 2016 - 01:47 AM.
#9 breizh
  • 6,328 posts
Posted 28 June 2016 - 02:11 AM
Let you use the "more reply option" and then attach the documents.
#10 Baqa Baloch
Baqa Baloch
  • 5 posts
Posted 28 June 2016 - 02:34 AM
Thank you,
Here are some pics of salt deposition.
#11 breizh
  • 6,328 posts
Posted 01 July 2016 - 04:33 AM
http://www.gewater.c...dbook/index.jsp
To support your work .
Consider to contact big names like Nalco /GE betz
