Vessel Thickness Calculation
#1 sayed sarfaraz
sayed sarfaraz
  • 3 posts
Posted 04 July 2016 - 05:11 AM
           Respected sir,
I calculate the thickness of vessel, it comes less than 1mm , following are the parameters, p= 13 kg/cm2, OD=6 in,length=15.76in , joint efficiency = 1,allowable stress for API 2H GR 50 MATERIAL = 20015psi,
t= P*R/SE-0.6P.
calculated thickness arise so much less whats the problem??
kindly suggest.
  • 6,334 posts
Posted 04 July 2016 - 07:05 AM
Hi Sayed,
Consider this resource to support your work :http://www.pveng.com...DesignTools.php.
Other possibility , the search engine in this forum  .
good luck
#3 srfish
srfish
  • 408 posts
Posted 04 July 2016 - 11:12 AM
Your thickness calculation is correct. The reason the thickness is coming out so small is because R is much smaller than usual. The normal R is much larger because vessels are usually much larger.
#4 curious_cat
curious_cat
  • 475 posts
Posted 04 July 2016 - 12:41 PM
For such cases the actual thickness is often governed by other factors like corrosion allowance, stiffness, fabricabilty etc.
Edited by curious_cat, 04 July 2016 - 12:42 PM.
#5 sayed sarfaraz
sayed sarfaraz
  • 3 posts
Posted 04 July 2016 - 10:54 PM
srfish:
How to increase thickness  or which factor we have to add ... since less than 1 mm vessels is not possible.,..
#6 sayed sarfaraz
sayed sarfaraz
  • 3 posts
Posted 04 July 2016 - 11:32 PM
Breizh:
Thanks sir
#7 Rizwan_Tahir
Rizwan_Tahir
Posted 27 July 2016 - 02:10 AM
Hi Sayed,
What is your design code? If you are using ASME Section VIII Div. 1, then material must be listed in UCS-23.
Rizwan
