hi
to simulation with aspen plus for gas dehydration TEG best thermodynamic model which is ؟؟؟؟
tanks
Posted 15 July 2016 - 10:53 AM
hi
tanks
Posted 19 July 2016 - 12:23 PM
I suggest you consider SR-POLAR, the Schwartzentruber-Renon equation of state for highly non-ideal systems. You may also appreciate the example simulation file teg.bkp which is typically available with your AspenPlus installation for you to use for learning or as a go-by.
Posted 19 July 2016 - 01:04 PM
How can I lunch a recoreded script (.scp) in background (hidden) in Aspen Hysys by a batch file?
Ammonium Sulfate Process SimulationStarted by Guest_amir55261_* , 06 Apr 2024 |
Olga And Aspen Simulation SoftwareStarted by Guest_CHEMSTRONG_* , 27 Mar 2024 |
Aspen Hysys SimulationStarted by Guest_amazingspidermean_* , 18 Mar 2024 |
Linear Alkyl Benzene Sulfonic Acid Production (Labsa) SimulationStarted by Guest_Emranm02_* , 03 Mar 2024 |
Stabilizer SimulationStarted by Guest_prashant.badgujar_* , 02 Feb 2024 |
