Effect Of Iron Content In Sulphuric Acid On Using The Acid In Batterie
Posted 05 August 2016 - 09:50 AM
Posted 05 August 2016 - 10:32 PM
Concentrated sulfuric acid (>98%) is transported in tankers. 98% Sulfuric acid does not cause corrosion. Only if water is present, the acid causes corrosion. Battery acid , which is dilute, is transported in polythene carboys or made on the spot by diluting concentrated acid in polythene carboys.
Posted 06 August 2016 - 10:05 AM
That is fine. I'm asking from the point of view of an acid manufacturer. Say if by chance corrosion takes place and 98% H2SO4 acquires some iron salt, and the acid is to be sold to as battery acid by some other vendor, is it likely to cause problems in the battery? Will there be any effect on the reaction taking place?
Sulphuric Acid H2So4 Storage TankStarted by Guest_TeeEng_* , 08 Apr 2024 |
Sulfuric Acid PlantStarted by Guest_Kartik54_* , 16 Mar 2024 |
Linear Alkyl Benzene Sulfonic Acid Production (Labsa) SimulationStarted by Guest_Emranm02_* , 03 Mar 2024 |
Multiple Effect Evaporator Calculation With Multiple ComponentsStarted by Guest_addiesalsabil_* , 13 Jan 2024 |
Sulfuric Acid Production / Partial Pressure Of H2So4Started by Guest_Jon K_* , 22 Sep 2023 |
