When you see "a visible stack plume even from a great distance" does it means that the plume stays visible for long distance without complete evaporation, or that the stack can be seen from long distance.
In the first case, it may mean that you have dissolved solids, the droplets concentrate until the water activity is in equilibrium with air humidity and don't completely evaporate. Here, your options are, a better demister (as rilmehta said above), scrubbing with a more diluted solution, adding a third scrubbing stage. Reheating may help, but is difficult to predict the effect with simple rules of thumb.
If it is only that the stack is in a conspicuous location, reheating or mixing with a hotter stream will reduce the visual impact. The calculation for eliminating fogging from stacks requires specific models. You may have an exit temperature that is above dew point, but when it mix with cold air it causes a fog plume anyway.
The following is a link to a commercial site I have no affiliation with, nor I have worked with them, just seemed illustrative to this issue.
http://www.envirowar...tted-by-stacks/
