Lift Gas at 90 kg/cm2g & 23 Deg C after pressure letdown to 11 kg/cm2g by means of PCV is used to empty out Crude Condensate Drum. In case of PCV failure, a protection with PSV available with set pressure of 47 kg/cm2g. What would be the relieving temperature of this PSV? Is it the temperature corresponding to let down of the Lift Gas from operating conditions to 51.7 kg/cm2g (10% of set pressure) which is around 5 Deg C or any other? Kindly let me know whether any standards related to above mentioned topic are available?
Relieving Temperature Of Psv In Control Valve Failure Case?
Started by sivaji1233, Aug 27 2016 02:02 PM
Posted 27 August 2016 - 02:02 PM
Posted 27 August 2016 - 04:54 PM
The temperature is whatever results from the relieving event. Why would you consider anything different?
Posted 29 August 2016 - 09:38 PM
For, relief condition (including PSV), we can refer to API 521. For CV failure, I used normal temperature for the calculation. Different with fire case (for example), it uses formula T1=P1/Pn*Tn where n=normal condition, 1=relieving T or P.
cmiiw
amad
Edited by amad, 29 August 2016 - 09:39 PM.
Wafer Check ValveStarted by Guest_Ali4269278331_* , Yesterday, 01:31 PM |
Caloric Temperature CalculationStarted by Guest_bckesim_* , 10 Apr 2024 |
Hydrocarbon Dew Point Control UnitStarted by Guest_BabRafiq1_* , 05 Apr 2024 |
Valve Cv InputsStarted by Guest_QuantumEng_* , 01 Apr 2024 |
