Hello
I am current handling a school project with a goal of separation of chemical products; MTBE, Methanol and 1-Hexane from a chemial waste solution tank. The chemical waste solution tanks contains of MTBE, Methanol, 1-Hexane and waste water.
Due to the low boiling points in the chemicals, MTBE, Methanol and 1-Hexane, ranging from 50 to 68 degrees. Is it advisable to use heating to evaporate the chemicals mixture of MTBE,Methanol and 1 Hexane from the waste solution, leaving waste water behind? The chemicals (MTBE,Methanol and 1-Hexane) in their vapor state will rise into a condenser to convert them back into their liquid state and collection is as follows.
Edited by Iamye, 29 August 2016 - 11:09 PM.
