Hello, I woud like to ask for any useful support, case studies, on the simulation of AGRU units with ASPEN Plus ?! I already have some experience with HYSYS but the transition to Aspen Plus isn't that obvious ... thank u in advance
Tutorials On Co2 Capture Aspen Simulation
Posted 11 September 2016 - 09:19 AM
Posted 24 September 2016 - 05:18 AM
As long as you know the basics of Aspen Plus, you must not have enough difficulty making your own models.
You can find built-in Aspen Plus models along with their PDFs in your PC.
Find them here: C Drive > Program Files > Aspen Tech > Aspen Plus > GUI > App
There are many models with amines, also physical solvent models are available.
Hope it helps.
Umer
Posted 25 September 2016 - 03:03 PM
In case of solid substances to produce CO2, you shall make the simulation by Aspen plus. Hysys cannot support solid materials.
You should be familiar with working in Aspen environment very well since, CO2 capture is a complex reaction.
How To Find K-Values Of A Hydrocarbon Mixture On Aspen Hysys?Started by Guest_Alexis Azamar_* , 08 Apr 2024 |
Ammonium Sulfate Process SimulationStarted by Guest_amir55261_* , 06 Apr 2024 |
Olga And Aspen Simulation SoftwareStarted by Guest_CHEMSTRONG_* , 27 Mar 2024 |
Answered
Centrifugal Compressor Performance Curves In Aspen HysesStarted by Guest_Rafcio_* , 14 Mar 2024 |
Aspen Custom Model Won't Load Into HysysStarted by Guest_SaintLazarus_* , 21 Mar 2024 |
