Dears
Usually by increasing temperature (in constant pressure) in fire heater liquid density decreases. But in the case I am working on, the feed is condensate, which will be heated from 200 °C to 320 °C. When pressure is above 5 bar, by increasing temperature the density will increase by 1~3 degrees and then will start to decrease.
I want to know the reason for such a behavior.
Thanks in advance.
