Dear sir
I'm working For a pharmaceutical industry. I have faced a problem with Humidity during reaction in a reactor. We have 4kl reactor with 20m2 shell and tube stainless steel heat exchanger. During reaction in the reactor brine circulation (-5 to 0 degrees) was running to the condenser. And vent of the reactor was opened. Due to that some moisture condensed in the condenser and fall down into the reactor. Because of that reaction was not moved properly. My doubt is how to avoid that moisture without stopping brine circulation to the condenser and how to calculate the Humidity/ moisture rate in litre/hr.
How To Calculate Humidity For A Condenser
Started by sateeshkumar830, Sep 17 2016 05:59 AM
No replies to this topic
Posted 17 September 2016 - 05:59 AM
How To Select Reboiler And Condenser Operating Pressures For A Mdea ReStarted by Guest_Alexis Azamar_* , 27 Mar 2024 |
Types Of Reboiler And CondenserStarted by Guest_refluxraider_* , 17 Mar 2024 |
Determining Operating Pressure For A Column Without CondenserStarted by Guest_phoroogh_* , 03 Feb 2024 |
How To Calculate The Thickness Of A Wall Of A Dewar?Started by Guest_Indehiscent_* , 30 Jan 2024 |
How To Calculate Cooling Rate Of CrystallizerStarted by Guest_snehchem_* , 04 Jan 2024 |
