Hi all, I am currently designing a flare system, in API 521 and API 537,it doesn't really say how to estimate the amount of gas that I need to vent,
I am assuming that on top of my normal process waste gas, i still have to factor in normal process upset. So my approach to design my flare is , it must be capable handling my normal waste gas, and handle vent gas generated by a 10% pressure offset by PRV, is this method correct? .
Another question is, let's say a column usually operated at 100 KPa, and the set pressure is 110KPa, how do I estimate how much vent gas will be generated if the column pressure reached 110 KPa ?
For simplification purpose, assume my column condition as below
Vapour flowrate=100 Mol/s
Column temperature=300K
Can anyone show me a simple example how to estimate the vent gas generated by a pressure relief if my example is bad ?
Very much appreciated!
Flare Design
Started by fhlee, Sep 21 2016 09:42 AM
Posted 21 September 2016 - 09:42 AM
Posted 21 September 2016 - 02:10 PM
There is no simple method to estimate relief requirements for a distillation column. Try the search engine on this site. I'm surprised that such an assignment is given to a student.
Posted 21 September 2016 - 05:59 PM
Hi Bobby,
Thanks for your feedback! Is my idea of designing the flare correct ( normal process gas+ relief requirement for different column) ?
Lee
Design And Fabrication Of Reflux DrumStarted by Guest_Femi_* , Yesterday, 03:05 PM |
Jt Based Hcdp Design V/s Mechanical Refrigeration Hcdp Unit.Started by Guest_BabRafiq1_* , 19 Apr 2024 |
Rupture Disc DesignStarted by Guest_chaupradip_* , 13 Apr 2024 |
Falling Film Reactor Design CalculationStarted by Guest_Emranm02_* , 07 Apr 2024 |
Handling The Limited Capacity Of Flare SystemStarted by Guest__1angelia23_* , 05 Apr 2024 |
