Cooling Tower Design
Posted 26 September 2016 - 08:35 AM
Temperature of water in = 60degC
Temperature of Water out = 15 degC
Ambient Air temperature = 8 degc
Relative Humidity = 30 percent
To cool 30m^3/min of water
I am finding it hard to get started with this but I am assuming I have to use the Merkel equation. Surely the heat load of the tower isn't as simple Q=cpmdeltat using the water inlet and outlet temperature?
Any help in the correct direction is appreciated. Thanks
Posted 26 September 2016 - 01:10 PM
Dear pads96:
It would be good to know if you are attempting an actual design of a cooling tower, or a simplified calculation regarding the streams involved, as taught in first years chemical engineering education.
For the simplified calculation, you usually use an "humidity chart" which let you obtain data regarding the air, like its specific enthalpy, so you can perform an energy balance.
Best regards.
Posted 26 September 2016 - 07:15 PM
pads96,
Use the search engine in this forum , you will find a lot of information , documents I posted for everyone to download .
Design And Fabrication Of Reflux DrumStarted by Guest_Femi_* , 22 Apr 2024 |
Jt Based Hcdp Design V/s Mechanical Refrigeration Hcdp Unit.Started by Guest_BabRafiq1_* , 19 Apr 2024 |
Rupture Disc DesignStarted by Guest_chaupradip_* , 13 Apr 2024 |
Falling Film Reactor Design CalculationStarted by Guest_Emranm02_* , 07 Apr 2024 |
