Following relief data are available in Lb/hr from different unit from refinery, All these PSVs are relieving in common flare.
UNIT 1:
PSV 01 (power failure case) : 129000
PSV 02 (power failure case) : 59000
PSV 03 (fire case) : 60000
PSV 04 (fire case) : 25000
PSV 05 (blocked outlet) : 85000
PSV 06 ((fire case): 2000
UNIT 2:
PSV 01 (fire case) : 45000
PSV 02 (fire case) : 29000
PSV 03 (fire case) : 15000
UNIT 3:
PSV 01 (Blocked Outlet) : 45000
PSV 02 (air cooler failure) : 29000
PSV 03 (Blocked Outlet) : 15000
PSV 04 (fire case): 35000
How we calculate the relief load for flare header or flare stack? or how we can set design flow rate for stack or flare header?
Edited by Arsal, 03 October 2016 - 04:57 AM.
