I want to simulate a stream containing MEG,water,salt and MDEA.
Around 70%wt of fluid is MEG.I know HYSYS limitations on simulation of salt.What is your recommendation for adding salt in HYSYS. You suggest using hypothetical option or any special solution?
Another question is about the proper fluid package or activity model for above composition and also above composition without salt.
thanks in advance
