I am a junior process engineer. I would like to calculate the volume of a gas to raise pressure in a pipeline by 1 bar. Please help me out.
The stream at outlet of compressor 1 is about 30 kSm3/h at 46 bar and 45°C, refer to the attached file for the stream composition. This stream is sent to compressor 2 to compress to 70 bar. The pipeline between these 2 compressors is 50m in length and 10" in diameter.
When the compressor 2 shuts off, pressure will raise up at downstream of compressor 1, this may cause shutdown of equipment due to high outlet pressure.
In this case, I would like to figure out how long will it take to raise pressure at downstream of compressor 1 by one bar, or reach the PSHH at 55 bar.
Thank you in advance
Edited by quangkhoa90, 23 October 2016 - 03:41 AM.
