I want to determine the flow rate of air which will be required to heat yogurt cups in incubation room from 25C to 45C with in 25 minutes, the material of yogurt cup is HDPE.
Flow Rate Of Air In Incubation Room
Started by Jawaria Zia, Nov 14 2016 10:01 AM
No replies to this topic
Posted 14 November 2016 - 10:01 AM
Flow Switch High RangeStarted by Guest_Lyne_* , 11 Apr 2024 |
Kettle Reboiler Flow FractionsStarted by Guest_Lyne_* , 31 Mar 2024 |
Ammonia Evaporation Rate InquiryStarted by Guest_aslungaard_* , 30 Mar 2024 |
Mtbe Process Flow Diagram Master Thesis.Started by Guest_sayoub_* , 15 Feb 2024 |
Duplication Of Psv And Flow Rate For Exchanger Tube Rupture ScenarioStarted by Guest_Platonicus_* , 11 Mar 2024 |
