Kero Loss In Disillation Tower
7 replies to this topic
#1 emerald
emerald
  • 4 posts
Posted 15 November 2016 - 06:43 AM
Dear all,
I hope you could help me find out some answers,
we use to operate our atmospheric distillation tower for a capacity of more than 15,000 tpd but recently when we increased more than 14,000 we face a problem of losing kerosene content. every thing is fine, except that the pressure drop is increased and kero is lost .
I hope you could help me in this.
thanks,
#2 Bobby Strain
Posted 15 November 2016 - 05:18 PM
Could be your crude is now lighter.
#3 Napo
Napo
  • 350 posts
Posted 16 November 2016 - 05:11 PM
Emerald,
If you lost kerosere production, maybe you have noted increase the diesel production or the diesel properties change.
If you have extraction column in "manual" (not in automatic)  you must be change the opening valve. Also you need to check the residue flow in the kerosene reboiler (this has a effect in the light product, more kerosene evaporated).
Napo.
#4 emerald
emerald
  • 4 posts
Posted 20 November 2016 - 02:33 AM
crude is the same ,
thanks for reply,
#5 emerald
emerald
  • 4 posts
Posted 20 November 2016 - 02:37 AM
Napo,
kero evaporated all with Naphtha (we had heavier naphtha) so, we suspect that the problem is the temperature of the trays above kero but we don't know how to decrease that temperature without changing the products properties,
thanks for your reply,
#6 Napo
Napo
  • 350 posts
Posted 20 November 2016 - 06:16 PM
Emerald,
Have you return to last charge?, if this charge haven't problem you can increase little a little the charge and you can find the problem.
Napo.
Edited by Napo, 20 November 2016 - 06:17 PM.
#7 emerald
emerald
  • 4 posts
Posted 21 November 2016 - 02:02 AM
Napo
we will do that,
thanks,
#8 AhmadJAQF
AhmadJAQF
  • 8 posts
Posted 16 January 2017 - 12:29 AM
check the top Temperature if it was high adjust it, and find the gap of the two products (5% and 95%) by that adjust your draw off carefully, and keep your eye on the level of the trays
all the best
