Platforming Fired Heater
Started by mhamdi khaled, Nov 16 2016 12:36 PM
Posted 16 November 2016 - 12:36 PM
Dears,
in the platforming unit the light naphtha coming from the first reactor with: T = 430 °c enter to the second section of the fired heater ( low part of radiant section) to get the energy and exit ( from the heighest level of radiant section) with T = 506 °c. the question is why the stream enter from the lowest part of radiant section ( not the heighest part).
note: cabin fired heater with horizental tubes and horizental burners (devided to three section).
thanx.
thanx.
Posted 16 November 2016 - 05:36 PM
Why Not?
Posted 16 November 2016 - 11:10 PM
Probably piping. If the inlet to reactors is from the top and outlet from the bottom, it makes sense to simplify the piping by sending from bottom of reactor 1 to bottom of heater and from top of heater to top of reactor 2.
Posted 17 November 2016 - 01:19 AM
boby,
normally the feed enter by heighest part of the radiant section because the skin points there is lower than meduim and low part.
Posted 17 November 2016 - 01:39 AM
Saml,
thank you for your response, but why we don't respect the temperature distribution in the radiant section.
Fired Heaters/ Burners/ Flue VelocityStarted by Guest_Lyne_* , 15 Mar 2024 |
Cross Temperature In Heater Exchanger (Lng)Started by Guest_Yogan_* , 21 Feb 2024 |
Why To Maintain The Skin Temperature At 150Degc In Fired Heater ?Started by Guest_johneyissac98_* , 12 Jan 2023 |
Simulating Single Drum Supplementary Fired Hrsg In Aspen HysysStarted by Guest_andry.at_* , 25 Aug 2022 |
Hydrogen Fired Steam Cracking FurnaceStarted by Guest_panagiotis_* , 17 May 2022 |
