Effect Of Simultaneous Operation Of Duty And Standby Pump On Pump Suct
Started by simadri, Nov 19 2016 08:42 AM
Posted 19 November 2016 - 08:42 AM
Hi All,
There is an existing facility with a liquid sulphur storage tank transferring liquid sulphur to destination by one duty (and one standby) centrifugal pump. Please find the attached sketch for the schematic diagram.
Pump Capacity: 120 m3/h
Suction & Discharge line size: 200 NB
Liquid Sulphur Density: 1800 kg/m3
Viscosity: 10 CP
In the existing facility, the pressure drop per is about 0.13 bar/100 m. Liquid velocity is 1.13 m/s.
Now, we need to run both the pumps simultaneously. Combined capacity of both the pumps is 240 m3/h. This will cause 2.26 m/s of liquid velocity with around 0.5 bar/100 m pressure drop. Both the velocity and pressure drop are considered as high for pump suction line.
My query is both the pumps will pump 240 m3/h of liquid sulphur causing possible vibration/ cavitation or the system curve will adjust automatically resulting into lower flow to destination.
Posted 19 November 2016 - 02:24 PM
"Both the velocity and pressure drop are considered as high for pump suction line"
You already have the answer.
If you checked that there is not enough NPSH or there are other issue that prevents that velocity in suction, then you cannot pump.
"system curve will adjust automatically"
The system will operate at the point where the parallel pumps curve and system curve meet. The usual thing you adjust to change the system curve is the opening of valves (normally a control valve), unless you have variable speed pumps.
Heavy Crude PumpStarted by Guest_Rahimzadeh_* , 13 Apr 2024 |
Pump Sizing ConsiderationsStarted by Guest_panagiotis_* , 07 Apr 2024 |
Piping Design_ Pump PipelineStarted by Guest_anh.phungthai@boydensvn_* , 29 Feb 2024 |
Design Considerations For Cryogenic Submersible PumpStarted by Guest_heydari_* , 04 Feb 2024 |
Variable Speed Pump CurvesStarted by Guest_panagiotis_* , 27 Jan 2024 |
