I need to calculate Shell and tube heat exchanger, process inlet flow quanitity, I have following details only
Tube side : Cooling water inlet temperature: 29.4 deg C / outlet temperature 32 deg C design flow rate 238 t/hr but in this case Cooling water outlet valve only 20% open
Shell Side: Process fluid -Heptane Inlet temperature :84 deg C outlet flow temperature 39 Deg C ,
Exchanger Design heat duty : 1.9 MMKcal/hr
Other details: Kindly check Attachment,
Please do the needful
-Kumar
