I want to know whether reverse flow scenario will be applicable for PSV sizing for the following scenario:
There is a MEG storage tank having working volume 2900 m3.
This tank will be filled during start up from a pump source ( 22.8 m3/h). This is let say source 1 start up line.
There are two different drain drum pump discharge line which gets joined together with the start up line and finally one common line will enter into the storage tank. At high high level, XV located on the common inlet line will get closed.
Each line from drain drum pump discharge is having normally closed valves and each of this is provided with dissimilar check valves.
Each drain drum is provided with a PSV, set pressure of which is less than maximum discharge pressure of pump from source 1.
Is reverse flow scenario applicable for each PSV of drain drum ?
As per I am concern, we should analyze reverse flow for PSV without considering any procedural control in place since PSVs are for ultimate protection.
Let me know what is your opinion.
Thanks.
Regards.
