Hi people;
I must calculate evaporation rate of a solvent from a gooseneck type vent on a tank to estimate an ATEX explosion zone. I have an equation for pool evaporation and opened tank but i can' t calculate evaporation rate of solvent in a tank from an orifice. Also i must consider wind speed.
Do you have any comments?
Evaporation Rate From A Tank Top Vent
Started by ersensan, Nov 23 2016 03:44 PM
Posted 23 November 2016 - 03:44 PM
Posted 23 November 2016 - 07:37 PM
Consider the resources attached to support your work. You may/should find pointers.
A good reference is "Chemical process safety fundamentals with applications " by D.A Crowl and J.F Louvar - Prentice hall.
Hope this helps.
Edited by breizh, 24 November 2016 - 03:51 AM.
Sulphuric Acid H2So4 Storage TankStarted by Guest_TeeEng_* , 08 Apr 2024 |
Ammonia Evaporation Rate InquiryStarted by Guest_aslungaard_* , 30 Mar 2024 |
Duplication Of Psv And Flow Rate For Exchanger Tube Rupture ScenarioStarted by Guest_Platonicus_* , 11 Mar 2024 |
Design Criteria For Sizing Sump Drum Of Close Drain System In Tank FarStarted by Guest_AnbIran_* , 28 Feb 2024 |
Vent Sizing Using GooseneckStarted by Guest_mychemicalromance0425_* , 23 Feb 2024 |
