Hello,
Good day everyone.
Recently working in a coal fired power plant industry (HP system). I just want to ask if there are calculations for dosing the right amount of chemicals such as TRISODIUM PHOSPHATE, NEUTRAL AMINE, and CARBOHYDRAZIDE with respect to the parameters (temperature, pressure, flow, pH, conductivity, load, etc) monitored in the boiler.
Just would like to have an idea in which I could calculate the right chemical dosings and later plot the actual performance such as residual phosphate, residual carbohydrazide and the like with respect to the monitored parameters so that I could come up with a trend.
In the power plant where I am currently working now does not have any calculations for dosing the right amount of chemicals but rather depend on estimations only. Well, estimations would be okay for basis of the adjustments but would also like to know the calculations for dosing the right amount so that I could relate also the estimations on the chemical adjustments with respect to the calculated values.
Hoping for your positive response.
Thank you in advance.
