Overall Coefficient Heat Transfer For Heater
overall coefficient heat tran
#1 Martyna
Martyna
Posted 28 November 2016 - 01:04 PM
Hello, first of all, I want to sorry every one for my english - it's not my native language. Sorry to say that, but I couldn't find as professional/helpful forum in my country, thats why I am looking for help here.
I need help with calculations:
There is a tank kept in temp. under 0deg. To keep the medium (water) above 4deg. in tank there is installed a coil. We know that this tank is losing Q=400kW. We know the geometry of the coil, material of it. The heating medium is water+glycol40% which has inlet temp. 80deg. The flow of it is 6m^3/s. We are looking for overall coefficient heat transfer.
Thats my idea for it:
I assume that the temp in tank is constant t=4deg so coil have to give to the water also Q, so:
m1*cp1*(t1-t2)=U*A*delta-t=Q
t2=t1-Q/m1/cp1 - outlet temp of heating medium
U=Q/A/delta.t                                  where delta.t=(t1-t2)/ln((t1-t)/(t2-t))
From this algorithm U=600 (every thing in SI units). It looks strange for me. Isn't it too big??
Edited by Martyna, 28 November 2016 - 01:16 PM.
#2 latexman
  • 1,680 posts
Posted 28 November 2016 - 02:58 PM
I'm sorry, I cannot follow your verbal description.  Draw a sketch.  Show all flows.  Show all temperatures.  Define the mediums.  Show all units.  Then scan it and attach.
#3 srfish
srfish
  • 408 posts
Posted 29 November 2016 - 01:06 PM
If you can achieve a heat transfer of greater than  about 1700 inside the tubing, it is possible.
