Hey friends
In our project, we have propane, butane and ethylene atmospheric double wall tanks.
Basic designer has not considered fire case for lp flare stack sizing.
In case of fire psvs will discharge to atmosphere.
Considering that these tanks are located in a crowd petrochemical complex, is it safe to discharge psvs to atm. ?
Fire Case For Flare Stack Sizing - Lpg Atmospheric Double Wall Tanks
Started by Ali-Jabbaran, Dec 22 2016 06:21 PM
Posted 22 December 2016 - 06:21 PM
Posted 23 December 2016 - 06:13 AM
Hi Ali,
It's not uncommon using large size emergency vent/rupture disc to release the huge relief load of fire case in the storage tanks containing flammable liquids to the atmosphere rather than conducting to flare system because in one hand the size of required header and stack will be abnormal and on the other hand a thin wall atmospheric tank engulfed in a pool fire unlikely can resist against failure due to over temperature.
Nevertheless there can be some facilities such as deluge system, dike walls and foaming system by which the consequences of the fire on mentioned tanks can highly be mitigated.
Posted 25 December 2016 - 11:36 AM
Thanks fallah for your prompt reply.
Pump Sizing ConsiderationsStarted by Guest_panagiotis_* , 07 Apr 2024 |
Handling The Limited Capacity Of Flare SystemStarted by Guest__1angelia23_* , 05 Apr 2024 |
Barometric Legs Line SizingStarted by Guest_panagiotis_* , 17 Mar 2023 |
Sizing Of Vertical/horizontal Flash DrumStarted by Guest_Mohammad3799_* , 10 Mar 2024 |
Design Criteria For Sizing Sump Drum Of Close Drain System In Tank FarStarted by Guest_AnbIran_* , 28 Feb 2024 |
