Design Of Pulsation Dampeners
pulsation dampeners pulsation dampers diaphragm pump
#1 Sherif Morsi
Sherif Morsi
  • 173 posts
Posted 06 January 2017 - 06:59 AM
We are about to purchase pulsation dampers for two new chemical injection pumps. The operating range is 5-20 lit/hr. The pump capacity is 75 lit/hr.
If we install the dampener based on the 5-20 lit/hr range and the operator needs to increase it to 30, 40 or 50 lit/hr, would that affect the dampener efficiency?
Would we need to install multiple dampeners to cover the whole range?
Sherif
  • 6,347 posts
Posted 08 January 2017 - 12:47 AM
Hi Sherif,
For dampeners you should consult the pump's vendor who normally supplies the dampener. Let you try with Milton Roy or other big name .
My view.
#3 Sherif Morsi
Sherif Morsi
  • 173 posts
Posted 09 January 2017 - 07:26 AM
Hi Breizh,
The pumps are actually Milton Roy :) They were installed 20 years ago and we are currently making changes to the discharge tubing. We are planning to purchase a couple of new dampeners. The operating capacity will be different from what was accounted for 20 years ago.
But thanks for pointing this out. I should go back again to them and see what they can do for us.
Sherif
