Reboiler And Condenser Temperatures.
Posted 14 January 2017 - 07:52 AM
and which of the column temperatures do you insert in the antoine equation to find your vapor pressures for relative volatility determination
Posted 14 January 2017 - 06:17 PM
Obed,
Temperature (T), Pressure (P) and Composition (x) are three parts of one equation. For any given mixture, if two of those parameters are fixed, then the third value is fixed as well. Refer back to TPx data in VLE. You only have 2 degrees of freedom.
In your column, you have stated the required composition of the liquid from the condenser (though you have not mentioned if its mol% or mass%). The column operates at atmospheric pressure (assumed). You should be able to find out the temperature as P and x are set.
Also, read about ethanol/water azeotrope.
Posted 16 January 2017 - 01:04 PM
Kettle Reboiler Flow FractionsStarted by Guest_Lyne_* , 31 Mar 2024 |
How To Select Reboiler And Condenser Operating Pressures For A Mdea ReStarted by Guest_Alexis Azamar_* , 27 Mar 2024 |
Outlet Temperautre Of ReboilerStarted by Guest_hysyshunter_* , 18 Mar 2024 |
Types Of Reboiler And CondenserStarted by Guest_refluxraider_* , 17 Mar 2024 |
Kettle Reboiler LengthStarted by Guest_Lyne_* , 26 Feb 2024 |
