Flare System
#1 DANA-IF
DANA-IF
  • 160 posts
Posted 16 January 2017 - 04:36 AM
Hello friends ;
I need  gudinace on some terms thet confused me:
- relief devices
-fire relief
-full flow relief
-pressure sefety valve (PSV)
-Emergency depressurisation system
-blow down system
-flare system
- Depressurisation analysis (fire blow down + cold blow down )
Thanks a lot !
#2 gegio1960
gegio1960
  • 517 posts
Posted 16 January 2017 - 04:56 AM
you could start here:
1) http://ballots.api.o..._2013_02-19.pdf
2) http://www.api.org/~...w/521 e6 PA.pdf
good luck
#3 DANA-IF
DANA-IF
  • 160 posts
Posted 24 January 2017 - 04:08 AM
Thanks a lot !
Im wondering please if you could share also API 521 'Pressure- relieving and depressurising systems' May 2008 ?
REGARDS!
#4 gegio1960
gegio1960
  • 517 posts
Posted 24 January 2017 - 04:17 AM
Unfortunately API publications are not free and are copyrighted... but if you work for a refinery or an engineering company they should have the book in their library  :)
good luck
#5 DANA-IF
DANA-IF
  • 160 posts
Posted 24 January 2017 - 04:35 AM
good luck
yes , we have but it's an old version (1997)
#6 gegio1960
gegio1960
  • 517 posts
Posted 24 January 2017 - 04:44 AM
That's good! In fact, the descriptions/definitions of the terms you're looking for clarification haven't been changed with the time. If you have more specific questions you can always ask to the forum experts: at least you'll have a common basisi for the discussion.
Edited by gegio1960, 24 January 2017 - 04:47 AM.
#7 fallah
  • 4,954 posts
Posted 24 January 2017 - 05:36 AM
DANA-IF,
Old version is adequate understanding the terms you mentioned in your first post...
Indeed, by Goodling you will have lots of materials can assist you to remove your confusion about mentioned terms...!
