Pressure Relief Valve In A Small Vessel/pipe
#1 CheAmine
CheAmine
  • 26 posts
Posted 29 January 2017 - 01:17 AM
We are currently in the process of designing a small vessel (or pipe) (ID: 400 mm, T-T:1700mm) that will be used to collect HC liquids from a pipeline and transfer the liquids to the closed drain. I would like to know if a PSV (i.e fire case) is required in this case for such small vessel which more or less like a pipe. note that the operating pressure is about 0.4 mbarg and the vessel will be installed above ground.
regards,
#2 chem2013
chem2013
  • 36 posts
Posted 29 January 2017 - 01:49 AM
Please check design code of this item and accordingly PSV requirement will come out.
Thanks.
Regards.
#3 fallah
  • 4,930 posts
Posted 29 January 2017 - 02:34 AM
CheAmine,
Such small volume of pipe segment (as a drip leg) connected to a pipeline appears doesn't need to be protected by PSV, but to make final decision more info and a sketch of the relevant system are required...
#4 SPC
SPC
  • 28 posts
Posted 08 February 2017 - 12:13 PM
CheAmine,
         A sketch is required for your system to understand.
Generally all hydrocarbon liquid drains are connected to a closed drain Header from where all liquid will flow to closed drain drum  (U/G) with Pump with Lift (Negative suction) is provided.
I do not your system to understand requirement of a PSV.
SPC
