Dear All, I am looking for pointers to design for PSV for Hot Oil Drain Tank with N2 Blanketing System. I am designing the PSV based on Fire case and Wetted vessel scenario, and I have made the following basis and would like to know if they are correct. During External Fire Scenario, hot oil tank and its contents (both Hot Oil and N2) that would be subjected to heat. How should I approach the sizing scenario for the PSV.
I) Should I size the PSV based on a wetted vessel (as it contains HOT Oil), and take into account the ONLY hot oil vapour generated due to heat, how about the N2 Gas Expansion?
II) I attempted to size it based on unwetted vessel , only taking into account of the N2 relieving, but I however think that this might not be appropriate and also I found that the Relieving Temperature exceeds the specified Wall Vessel Temperature (1100F) due to big difference between the N2 Blanket Operating pressure(1.08 BarA) and High PSV Set Point (4.5 BarG).
Or I should size for both scenario and take the worst case scenario? Please advise. I have summarized my key findings for both cases with the suggested orifice area for reference. Thank you Colin
Edited by isidore, 16 February 2017 - 02:54 AM.
