i'm a beginner while working with ChemCAD and so I need to familiarize with the program.
Anyway, I tried to simulate a rektifikation with a SCDS column. Everythink worked fine instead of the reflux ratio. I need to simulate the rektifikation with a special reflux ratio from 5:1 and 10:1. The problem is, that I cannot find the option for setting the right reflux ratio.
Hope you can help me.
Thanks!
Reflux Ratio Chemcad 5.1
Started by Phoenix23, Jun 03 2007 07:35 AM
Posted 03 June 2007 - 07:35 AM
Posted 08 June 2007 - 05:35 PM
Phoenix,
When double-clicking SCDS column in the flowsheet, there should be one special menu to appear. Under "Specifications" tab and "Condenser option" from the drop-down list select "Reflux ratio (R/D)", and give an initial estimation whichever you want.
Design And Fabrication Of Reflux DrumStarted by Guest_Femi_* , 22 Apr 2024 |
Simulate Desiccant Dehumidifier In Chemcad 7.1.2Started by Guest_Tamar_* , 15 Dec 2023 |
Ratio Heat To ElectricalStarted by Guest_panagiotis_* , 02 Dec 2023 |
Split Flow Between Two Pipes At RatioStarted by Guest_Abiodun1_* , 30 Oct 2023 |
Condensate Gas Ratio (Cgr) CalculationStarted by Guest_Mohamed_Mamdouh_* , 14 Aug 2023 |
