Dear all,
Whenever designing the GES EJECTOR ,the molicular weight of the gas is important factor or not?kindly inform about the design method or resourses.
dhns,
Gas Ejector Design-molicular Weight
Started by dhns, Feb 06 2008 02:53 AM
Posted 06 February 2008 - 02:53 AM
Posted 08 February 2008 - 01:58 AM
Mass and volumetric flows of suction gas are inter-dependent variables, and factor is molecular weight.
Quotation:
"For the most effective design of a jet vacuum pump the following data are required:
Suction medium:
- composition, mol mass [kmol/kg]
- suction flow ·M0 in [kg/h] or [kg/s]
- suction pressure p0 (absolute pressure) [mbar]
- temperature T0 [°C]
- counter pressure p (absolute pressure) [mbar]
Motive medium:
- pressure, p1 (over pressure or absolute pressure) [bar]
- temperature T1 [°C]
Cooling medium:
- temperature[°C]
- head pressure [bar]
These data determine arrangement, number of stages, motive and cooling medium consumption."
Source: GEA Jet pumps
More info at: http://www.geajet.co...bDoc/ndkw74bhlw
and: http://www.graham-mfg.com/
I hope this helps in your query. I remember GEA website had very useful charts for estimating ejector load/size, but I couldn't find them.
Quotation:
Suction medium:
Motive medium:
Cooling medium:
- temperature[°C]
Posted 30 January 2009 - 07:01 AM
Dear Zauberberg,
Thanks for your valuble reply message and resersources links.
reg,
dhns.
reg,
dhns.
Vacuum Ejector Pressure ControlStarted by Guest_himanshu.ch_* , 19 Mar 2024 |
